Textured ceiling
JCGD
Hello, new to this forum. We recently just moved into our forever home. Bungalow was built in 1982 and has had a few extensions through the 90s. All ceilings are smooth apart from the hall. Does this look like artex? Was wondering if it’s worth getting a survey done.4A3A0231-423C-4BE1-A0FC-120E67C556F4.thumb.jpeg.277971f98a4cfd823a4485c8e0d0e832.jpeg
8 minutes ago, Conor said:
Are you planning on pulling it down? If not, forget about it, it's not a risk.
Looks more like textured rolled plaster. Just scrape a sample off and send it off for testing.
Over the next few years we will be doing work to the property, probably will replace lights etc in the hall, so probably worth getting it tested then.
