Just thought I'd mention that Myson have a handy little windows application - 'E2 Heat output calculator' that allows you to easily play with flow/return temps and room heat requirements to size your rads.
Although I have been using the Freedom heatpumps toolkit to do my rad sizing, their default deltaT is 30 degrees, which implies a flow temp of 50. The Myson software allows flow, return and room temp to all be easily adjusted.
Available for free from: Software by MYSON
