Esbe diverted valve
Alwayslearning22
Mine did the same, but it would move when I just knocked it. Problem was the actuator, not the valve. I would try taking the actuator off the valve (usually you have to unclip a wire) If the valve is stuck the actuator should then move. Otherwise the issue may be the actuator.
Thanks for the reply. Do I need to drain some water from the system to do that? They must be very temperamental
No, you shouldn't need to drain anything. Actuator is separate from valve. Once you've removed it, you'll see the valve which you should be able to turn manually with a pair of pliers if it is not totally seized.  If you're not sure how to remove it, look up the manual online.
