I'm considering buying a weather compensation kit for my system boiler.
It's configurable and allows you to choose the curve required for your system. There are a couple of options;
Curve 30
Outside Temp: 20c. Flow Temp: 47c
Outside Temp: 0c. Flow Temp: 73c
Curve 20
Outside Temp: 20c. Flow Temp: 20c
Outside Temp: 0c. Flow Temp: 52c
Curve 30 seems useful for the colder periods, especially for the upstairs rads until I fit IWI, but given I also use the boiler to heat our unvented cylinder, neither seem appropriate in the summer months.
Ultimately, I hope to heat the hot water using PV in the summer months, so the boiler would be off altogether. In which case, is weather compensation actually that useful?
You really need the heating and boiler capable of giving different temperatures for DHW heating and central heating, otherwise it's pretty much a waste of time.
If you set it up well it may be worth while.  For WC to work properly you run the heating 24/7 with a setback of a couple degrees overnight.  So ideally you heat DHW at night when the boiler isn't doing much work.
