Hi
In our bungalow conversion project we are having a new solid floor put in. Build up is hardcore, concrete slab, PIR, UFH pipes, screed. The original floor was joisted and floorboards.
however when I took a section of the wall down today, both inside and outside had 2 courses of blue bricks but the outside course was a brick higher than inside.
Is this normal/standard?
what level would you put your new floor too?
All advice/help much appreciated
Many Thanks
If the ground under the floor is firm and inert you are better off with a bit more insulation and less hardcore.
Blue bricks are sometimes used instead / as well as a DPC.
You probably want you finished floor similar to the existing so internal doors and external thresholds are the same.
