The best deals for laminate flooring
JohnBishop
14 hours ago, Simplysimon said:
costco stuff is usually good quality  https://www.costco.co.uk/search?text=Laminate Flooring what sort of guarantee do the others offer?
8mm - heavy use - 20 years domestic use (living room, higher traffic areas)
7mm - medium use - 15 years domestic use (bed rooms)
The Costco ones are almost twice as thick.
I checked the doors and on the ground floor and in the dining doom there is at least 18mm clearance and between 25 and 30mm in the living room.
Upstairs it is at least 22mm clearance but I put the wood fibre underlay boards only.
I could consider a much thicker boards downstairs. Wherever I read they say to put 5mm underlay boards but do I have to do it if laying thick 12mm+ boards and on concrete?
I think I meant Factory Direct Flooring has the best deals IMHO https://www.factory-direct-flooring.co.uk
Wood Floor Warehouse - is more expensive on smaller orders and the delivery is a bit pricey. They don't go under £60 on delivery
Edited by JohnBishop
