JohnBishop Posted August 26, 2022 Share Posted August 26, 2022 Hi All, Would you suggest any other suppliers? I am after 7 and 8mm thick laminate boards. I have looked into Woodfloor Warehouse https://www.woodfloorwarehouse.co.uk but Flooring King is cheaper for under 30sqm orders. https://www.flooringking.co.uk Have you seen any better deals? Thanks Link to comment Share on other sites More sharing options...
Simplysimon Posted August 26, 2022 Share Posted August 26, 2022 costco stuff is usually good quality https://www.costco.co.uk/search?text=Laminate Flooring what sort of guarantee do the others offer? 1 Link to comment Share on other sites More sharing options...
JohnBishop Posted August 27, 2022 Author Share Posted August 27, 2022 (edited) 14 hours ago, Simplysimon said: costco stuff is usually good quality https://www.costco.co.uk/search?text=Laminate Flooring what sort of guarantee do the others offer? 8mm - heavy use - 20 years domestic use (living room, higher traffic areas) 7mm - medium use - 15 years domestic use (bed rooms) The Costco ones are almost twice as thick. I checked the doors and on the ground floor and in the dining doom there is at least 18mm clearance and between 25 and 30mm in the living room. Upstairs it is at least 22mm clearance but I put the wood fibre underlay boards only. I could consider a much thicker boards downstairs. Wherever I read they say to put 5mm underlay boards but do I have to do it if laying thick 12mm+ boards and on concrete? I think I meant Factory Direct Flooring has the best deals IMHO https://www.factory-direct-flooring.co.uk Wood Floor Warehouse - is more expensive on smaller orders and the delivery is a bit pricey. They don't go under £60 on delivery Edited August 27, 2022 by JohnBishop Link to comment Share on other sites More sharing options...
JohnBishop Posted August 27, 2022 Author Share Posted August 27, 2022 (edited) The ones I was thinking about: https://www.factory-direct-flooring.co.uk/prestige-8mm-castle-oak-ac4-laminate https://www.factory-direct-flooring.co.uk/prestige-natur-oak-7mm-v-groove-click-laminate-flooring-3903 https://www.factory-direct-flooring.co.uk/prestige-7mm-spirit-oak-nature-laminate-flooring-3125 The thickest they have is 12mm and it's rated for 25 years, heavy domestic use https://www.woodfloorwarehouse.co.uk/oxford-oak-grey-brown https://www.woodfloorwarehouse.co.uk/natural-charlotte-oak https://www.woodfloorwarehouse.co.uk/achensee-oak but again it turned out more expensive. Floor King has this one I like but again this has to be ordered from the same supplier otherwise I lose on deliveries: https://www.flooringking.co.uk/shop/laminate-flooring/cfs-lam/cfs-supernatural-classic-8mm-harlech-oak/ Edited August 27, 2022 by JohnBishop Link to comment Share on other sites More sharing options...
