Lee Brush Posted August 6, 2022 Posted August 6, 2022 Does anyone have any experience with lime torching ? In my barn I have an exposed tile roof (see picture), I don't want to put on a new roof. This will be a work space not a living area so it does not need to be cosy just comfortable. I have read a bit about lime /plaster/horsehair mixture that is applied to the underneath of the tiles. It acts as a buffer agains wind blown rain, a mortar to secure tiles and also as a form of insulation. Any links or tips would be greatly appreciated.
nod Posted August 6, 2022 Posted August 6, 2022 Yes I’ve done lots of it as part of my business Mainly on barns and farm buildings It’s known as barging locally to me Don’t buy the tubed stuff It will cost you a fortune Mix 3 sharp sand to 1 hydrated lime Don’t over mix We normally max the sand and water for five minutes then add the lime Goggles hat and a disposable suit This stuff burns Its applied the opposite way to plastering Fill your trowel and push away and Down Very cheap to do yourself Some pictures of you before and after will be good to see 😁 1
Lee Brush Posted August 7, 2022 Author Posted August 7, 2022 10 hours ago, nod said: Yes I’ve done lots of it as part of my business Mainly on barns and farm buildings It’s known as barging locally to me Don’t buy the tubed stuff It will cost you a fortune Mix 3 sharp sand to 1 hydrated lime Don’t over mix We normally max the sand and water for five minutes then add the lime Goggles hat and a disposable suit This stuff burns Its applied the opposite way to plastering Fill your trowel and push away and Down Very cheap to do yourself Some pictures of you before and after will be good to see 😁 Thanks for the reply Nod, I appreciate the info, I am in Italy I found a local company that uses hemp instead of horse hair they sell it by the sack its not too pricey. Also appreciate the safety advice
nod Posted August 7, 2022 Posted August 7, 2022 (edited) 7 minutes ago, Lee Brush said: Thanks for the reply Nod, I appreciate the info, I am in Italy I found a local company that uses hemp instead of horse hair they sell it by the sack its not too pricey. Also appreciate the safety advice If plastering is the dirtiest trade Barging is the dirtiest job Dont forget the pics 😁 Edited August 7, 2022 by nod
