Stones Posted June 4, 2017 Posted June 4, 2017 Whilst doing so groundworks the other day, I had to remove a riser from our treatment plant inspection chamber. I took the opportunity to take a quick sample of the treated effluent to see how clear it was and if there was any detectable odour. I'm pleased to say it was both clear and odour free. The treatment plant itself (Biopure) appears to be working as it should, the air pump diffusing air into the central digestion chamber, with the outer chamber topped by a layer of scum which I believe will eventually form into a crust. I'd like to be able to test the quality of the treated effluent, to see how clean said effluent is (and whether the results match the manufacturers stated performance) but I can't seem to find any kits to do this, other than by spending a fair chunk of cash: http://www.camlab.co.uk/palintest-sewage-effluent-kit-p26092.aspx Just wondering if anyone else has self tested their treatment plant effluent and what did they use?
readiescards Posted January 27, 2018 Posted January 27, 2018 Would love to know what solution you came up with - if any
