i cant seem to find this info anywhere ,  can i wall tie/ furfix . if you imagine a brick wall and concrete blocks butting up to the back of it cheers
So,brick elevation on one side,with render or cladding on the blockwork return?
If it’s render,I’d go for a quoin detail,with the blockwork set back the depth of the render,so when applied it’s flush with brickwork.
