davejura Posted June 30, 2022 Posted June 30, 2022 Hi folks. Looking for recommendations for a suitable VCL. Make up is Hardieplanks on sw battens with 38mm ventilated cavity, Protect TF200 thermo, 9mm OSB, 145mm studs with 140mm PIR between, VCL, 30mm PIR, 38mm cavity, 12.5mm plaster board. Architect has just specified "vapour control barrier" so just wondering if anyone can recommend any particular type. Thanks.
Thorfun Posted July 1, 2022 Posted July 1, 2022 Intello Plus is the bees-knees but there are many on here that have had great success with other less expensive brands. I bought the Intello Plus (and the Tescon tape) from Latzel in Germany following advice from this thread: there are many threads about different VCLs on the forum. do a search and have a read and then decide which is in your budget!
