Heavenly Posted June 23, 2022 Posted June 23, 2022 (edited) Hi, I got approval for planning permission in a conservation area. The house was built in the late 1960s and is in red brick. Works: a double storey extension and the reorientation of the roof (new) parallel to the road. As part of the schedule of works I asked my builder to include removal the chimney breast from inside the house as it was taking up too much room. As a consequence it meant no chimney stack, this doesn’t bother me. I asked my architect he did seem to think it was a problem. However, I am now worried that once the build is completed someone will notice that the house is missing a chimney stack. I would be grateful for some guidance. Thank you in advance. Edited June 23, 2022 by Heavenly
Conor Posted June 23, 2022 Posted June 23, 2022 Submit a non material change application to the planners and see what they say. I think any change like that in a conservation area will require approval. Is it prominent? E.g. an external stack that goes high above the roofline? Is is a defining feature of the property and others near by? Or is it an internal stack with just a short stub on the roof? If the latter you probably won't have an issue... Worst case you might have to fit a fibreglass copy.
Heavenly Posted June 23, 2022 Author Posted June 23, 2022 (edited) I need to edit, to include this: I asked my architect he didn’t seem to think it was a problem. Edited June 23, 2022 by Heavenly
Heavenly Posted June 23, 2022 Author Posted June 23, 2022 11 minutes ago, Conor said: Submit a non material change application to the planners and see what they say. I think any change like that in a conservation area will require approval. Is it prominent? E.g. an external stack that goes high above the roofline? Is is a defining feature of the property and others near by? Or is it an internal stack with just a short stub on the roof? If the latter you probably won't have an issue... Worst case you might have to fit a fibreglass copy. Thank you for your reply, the external stack is fairly short in height. See plan shot
Mr Punter Posted June 23, 2022 Posted June 23, 2022 Best to get the amendment agreed by the planners. It would be really annoying to finish the extension and later have to erect scaffold to fit a GRP replica stack
Heavenly Posted June 23, 2022 Author Posted June 23, 2022 Thank you Mr Punter, but how would a chimney stack be installed without a chimney breast to support it, the upper floor will be completely new, the existing ground will have the old chimney breast removed. Unless I get a replica stack installed as part of the build. We are a few months away from touching the existing roof.
Heavenly Posted June 23, 2022 Author Posted June 23, 2022 Actually, the replicas look very realistic but would I need to to anyone it’s not real ?
