jfb Posted May 26, 2022 Posted May 26, 2022 (edited) I think I asked a while back about this but cant find the thread. I'm wondering if my plan for alarms is acceptable. Its a small barn conversion (70m2 total) with an open plan downstairs (except for lobby/toilet) and 2 beds/bathroom/landing upstairs. Looking at the plans below I am planning on a heat alarm where the 'h' in kitchen is (downstairs - first image) and a smoke alarm in the landing at the top of the stairs in the second image. I am thinking that is sufficient - would that be correct? Is there a minimum distance a heat alarm should be from a cooker? Also - am i right in thinking it should be wired in 3 core and earth (1.5mm) radially on its own circuit? Edited May 26, 2022 by jfb
Nickfromwales Posted May 26, 2022 Posted May 26, 2022 (edited) Technically yes, but only your BCO can give you a final answer for your dwelling. We can only procrastinate I'm afraid. I would install one on the edge of the living room ceiling tbh. 3c + E yes. Regular twin and earth from CU to 1st detector. I'd be looking for 3m distance away from cooker / oven / kettle etc so as to not get nuisance alarms. Edited May 26, 2022 by Nickfromwales 1
