Willowash Posted May 23, 2022 Share Posted May 23, 2022 (edited) Hi all I have just had some windows and doors fitted to our property, and on inspection was not happy with what I found. The main problem is with the bay window and more to the point the bay posts and their fitting (or lack of it) I have had several conversations with the manager of the company involved who has told me that there is nothing wrong, as you can see the bay post isn't sat on the sill and nether is the window frame these are the photos I have sent to him and he as also come out to inspect when we were not in. I would appreciate any feedback from you thanks Edited May 23, 2022 by Willowash File not added Link to comment Share on other sites More sharing options...
Willowash Posted May 23, 2022 Author Share Posted May 23, 2022 Some pictures Link to comment Share on other sites More sharing options...
Willowash Posted May 23, 2022 Author Share Posted May 23, 2022 Link to comment Share on other sites More sharing options...
Miek Posted May 23, 2022 Share Posted May 23, 2022 Look like they don't fit. Not very good at all. If they were supply and fit then they should sort it out. If you measured up yourself then that's on you. A bay window is a bit trickier to measure but still run of the mill stuff for a window fitter.. 1 Link to comment Share on other sites More sharing options...
Willowash Posted May 23, 2022 Author Share Posted May 23, 2022 3 hours ago, Miek said: Look like they don't fit. Not very good at all. If they were supply and fit then they should sort it out. If you measured up yourself then that's on you. A bay window is a bit trickier to measure but still run of the mill stuff for a window fitter.. These were done by a big window company supplied and fitted by them this is the finished windows I was left with and am in the process of a complaint Link to comment Share on other sites More sharing options...
Miek Posted May 24, 2022 Share Posted May 24, 2022 7 hours ago, Willowash said: and am in the process of a complaint Quite right. Link to comment Share on other sites More sharing options...
gaz_moose Posted May 25, 2022 Share Posted May 25, 2022 is the company FENSA or CERTAS approved? sounds like you need to be speaking to them. looks like they have got the angles wrong on the bay. Link to comment Share on other sites More sharing options...
Willowash Posted May 25, 2022 Author Share Posted May 25, 2022 10 hours ago, gaz_moose said: is the company FENSA or CERTAS approved? sounds like you need to be speaking to them. looks like they have got the angles wrong on the bay. Yes they are FENSA approved I have requested that the manager comes out to look at the work with regards to rectifying the work Link to comment Share on other sites More sharing options...
