I have a 6kW inverter donated by a kind BH member, so I decided to buy more panels today and put it to use as I have had good success with my smaller array using micro inverters.
So I decided to setup the bigger inverter so I could connect it to the Wi-Fi etc. however, no dice. It's all hooked up on the AC side, but nothing lights up on the LCD screen - so the question is, do some models not fire up unless the DC side is active? I did plug in a single panel I have in my garage just to show the inverter a non-generating closed circuit, but to no avail.
I know my micro inverters, when plugged into the mains, with a PV string attached but no DC generation do nothing, they look dead, you would only get a fault warning LED if the string was generating without AC connected.
The inverter manual is a bit poor - Goodwe GW6000D-NS is the model.
Thoughts welcome.
Edited by Carrerahill
