CharlieKLP Posted May 8, 2022 Share Posted May 8, 2022 (edited) It’s so easy to fix it, just cut the games room lengthwise, then you have two useable rooms, both with windows. I’m not sure why you aren’t doing that, it looks obvious to me. Unless you have some plans for your 2m corridor room. Edited May 8, 2022 by CharlieKLP Link to comment Share on other sites More sharing options...
oadbyone Posted May 9, 2022 Author Share Posted May 9, 2022 18 hours ago, CharlieKLP said: It’s so easy to fix it, just cut the games room lengthwise, then you have two useable rooms, both with windows. I’m not sure why you aren’t doing that, it looks obvious to me. Unless you have some plans for your 2m corridor room. Cheers, I did think about that when first planning it but before I knew about the issues with inner rooms I thought it would be better without any windows!! Plus the way I have it makes it really simple to build, if I split the room and use the far end for the cinema room it would involve moving some downlights and a radiator, I was a the top end of my budget but I might be able to stretch it. You have got me thinking now and i'll have a look at it again as it would be a better option and better space. Out of interest is it OK to build a stud wall over one of the windows at the far end of the room? Not sure if there would be any issues with this. Link to comment Share on other sites More sharing options...
oadbyone Posted May 10, 2022 Author Share Posted May 10, 2022 Hi, I have changed the plan as suggested by CharlieKLP which is a much better, slightly larger space. I guess this would be acceptable to do without BC input as there is a large window with two openings for escape and ventilation. The only thing i'm not sure about is that there is a window on the right wall which I would need to stud/dry wall over, are there any potential issues with this other than if it would need maintenance? Cheers. Update plan.pdf Link to comment Share on other sites More sharing options...
oadbyone Posted May 10, 2022 Author Share Posted May 10, 2022 1 hour ago, oadbyone said: Hi, I have changed the plan as suggested by CharlieKLP which is a much better, slightly larger space. I guess this would be acceptable to do without BC input as there is a large window with two openings for escape and ventilation. The only thing i'm not sure about is that there is a window on the right wall which I would need to stud/dry wall over, are there any potential issues with this other than if it would need maintenance? Cheers. Update plan.pdf 363.18 kB · 2 downloads Added a jpeg as I think you have to download PDFs Link to comment Share on other sites More sharing options...
