Best way to add shelf above panelling
Hi All,
I was wondering if anyone could give me some advice. My partner and I want to install wall panelling that covers 3/4 vertically of a wall. We'd like to run a floating shelf along the top of the panelling so we can rest pictures, pots, decorations, etc.
What would be the best way to install the shelf?
Thanks,
Adam
Depends on width and thickness of shelf but dowels drilled into the walls and corresponding holes in the shelf so the shelf slides onto the dowels. works well, but needs accuracy in drilling.
dowels are either steel round bar or threaded rod or small diameter alu tubing with long screw into wall plugs
Edited by markc
