New build in progress.
Stud wall under attic truss. Fix to truss? Are cracks in plaster likely to develop when truss deflects with loads?
If so, is there a trick to reduce the risk of cracked plaster?
Perhaps some kind of movement joint material between head plate and truss tie beam?
9 hours ago, PeterW said:
Do the ceiling first and then do the stud below
Builder schedule is stud walls first (already begun) & later ceiling, for better or worse
