Has anyone come across Dream air to water heatpumps?
They have different products in swimming pool and home heating sections. This one's for home. Cheesy website. Pretty obviously Chinese.
- Heat Output : 5KW
- Heating Power Input : 1.1KW
- Voltage/Phase/Frequency : 220-240V/1PH/50HZ
- Toshiba Rotary Compressor
- Stainless Steel Heat Exchanger
- Digital LCD Controller
- Refrigerant Type : R410A
- Coefficient of Performance (COP) : 4.9
- Water Flow Rate : 0.8 m3/h
- Hot Water Supply : 107 L/H
- Maximum Hot Water Temperature : 60 ºC
- Sound Level : 48 dB(A)
- Water Connections : 3/4 inch
Spec wise it seems to fit the bill for me to heat a 24m2 UFH loop and possible a single 2.5kW radiator. No mention of inverter.
£1200
A quick look at the dimensions, not going to have a very large radiator in in, and it sees a bit light.
I take it is is not an inverter driven model.
Kind of thing that would suit me as well, so I am going to recommend you get one, then report back.
 OK then.
Might give them a ring tomorrow to see if they can give any more info. Some second-hand pool heating variants coming up on Ebay allegedly still working. Obviously not totally unheard of in the UK.
We were fitting them 35 years ago in the UK market.  Customers loved them.
