BadgerBadger Posted March 19, 2022 Posted March 19, 2022 What's the best way of getting power and water to outside the of a wall? e.g. for external taps and power sockets. We're just starting foundations and substructure - masonry walls with beam & block floor. Is there anything clever we could be doing to make it easier later on, such as putting some ducting through the substructure?
PeterW Posted March 19, 2022 Posted March 19, 2022 Nope just drill through with a 25mm masonry bit and sleeve with 25mm conduit and seal each end with lots of low modulus sealant.
Temp Posted March 19, 2022 Posted March 19, 2022 If you plan to have power in an outbuilding/detached garage or electric car charger I'd run some duct pipe through the founds near the CU/meter. Other possibility would be a duct and draw rope while you still have a digger for the trench? Oherwise what @PeterWsaid.
