Change of use from agricultural building to
dwelling using permitted development rights
do you still need to apply for full planning or just change of use and bulding regs
You need to submit a Prior Notice "application" rather than a Planning Permission application.
Much less work. Initially just a a few lines on an OS Map showing foot print, curtilage and extent of land owned within Agricultural Unit. If successfull you'll then probably have a Design and Appearance pre-commencement condition to satisfy requiring elevations and floorplan.
Some LPA's insist that all is included within the initial application, but the legislation says it can be dome in two parts.
You need to know what you are doing with the PN. There's a lot to how you "present" the building and avoiding making a mistake that may stop any PD development for 10 years. Try a find a local Planning Consultant that's got a good success rate with Class Q PD's
Edited by IanR
