Adam E Posted March 6, 2022 Posted March 6, 2022 Hi trying to turn off freeze stat, I have a 8.5kw ecodan latest version when you see the time the freeze stat was used and the fact that the system has Glycol I would like to turn this off on previous posts it mentions auxiliary settings but can’t find freeze stat anywhere is it a dip switch settings? Any help appreciate Adam
TW9 Posted March 8, 2022 Posted March 8, 2022 I've dusted off my Ecodan manuals. Your pic shows Auxiliary settings. If you go up one level you should see Operation Settings. Under this there should be Freeze Stat Function with two options. Flow temp and ambient. My manual doesn't say what each option does.
