Adam2 Posted February 25, 2022 Posted February 25, 2022 We have a lot of glazing! Half of it was specified to be Pilkington Suncool opti-white 66/33 or equivalent with self-cleaning. The glazing co of course says that is what we have provided by Guardian Glass. Any ideas on how I would go about ensuring this is 100% the case? The shading effect was v important and I'd like the warm glow of reassurance ? Is there a practical way to check? I did ask for confirmation and got sent some specs from Guardian that were hastily produced in the last couple of days so clearly not something taken from my supplier/installer's order with them which was months ago.
craig Posted February 25, 2022 Posted February 25, 2022 (edited) Check the spec, if UK glass it’s usually etched in the corner (visible) you’ll need to check. If European, it’s usually marked on the spacer bar. Edited February 25, 2022 by craig
Adam2 Posted February 25, 2022 Author Posted February 25, 2022 52 minutes ago, craig said: Check the spec, if UK glass it’s usually etched in the corner (visible) you’ll need to check. If European, it’s usually marked on the spacer bar. Thanks - I did see some impossibly small writing in the corners! Will take a camera and a piece of paper so hopefully can get a clear image of that
