Edward Posted February 7, 2022 Posted February 7, 2022 We need to replace our roof soon. It’s not far of 100 years old, we can see daylight through the roof, it leaks, is covered in moss which the birds pick at which further damages the roof, so…. What alternatives are there to the traditional roof tile, like a composite fitting or something, which will tolerate UV, cold, snow ice and hot temperatures? I have literally no knowledge on this topic so any insight would be useful. Would you trust the advice of a roofing contractor on materials or would you request a contractor installs a material of your choice? More than likely too is that the timber frame would need replacing as I suspect it could be in a better condition.
SteamyTea Posted February 8, 2022 Posted February 8, 2022 Have you looked into roof integrated PV? If your angles are right, fairly cheap alternative, and you get some power from them.
