Morning all,
I'm struggling to get the dimensions I want with the number of outlets required., I'm looking at a space of 330mm between joists and about 300mm from underside of floor to ceiling...  Has anyone made up their own manifolds?  What materials did you use to construct, how can you connect the ducts to the box...   If you have documented your construction, it'd be great if you could point me in the right direction.
Many thanks.
