Have had a search through old threads on a similar topic, and wanted to check I’ve understood correctly - apologies for rehashing old questions!
House is 170 sqm, 3 bed. UFH has been installed in 50 sqm of the property with 150mm PIR under screed. Rest of property is heated w rads. Boiler is a 32kw Grant Combi, occupants 2 adults 2 teenagers. Will a 120 ish litre buffer tank suffice for the UFH? Mains pressure is good, flow a little on low side, around 15 l/m, we are on a spur off the main feeding 3 properties, have spoken to salamander technical, wondering if we need an accumulator?
many thanks
