No noise on mine, really really pleased I did it, wouldn't go back now.
Get a manifold and 75mm semi-rigid pipe to help cross talk between rooms, plus its easier to self install using this method.
1 hour ago, Si3 said:
Advice here is brilliant, thanks all. With regards to the noise is one of those things you only notice after it’s installed, and the. Just blends into the background?
Like @Marvin there's zero tolerance for noise in this house! Our unit is mounted on isolating mounts in the loft and whilst this is right above our bedroom you can't hear it. In normal use the air flow isn't audible either (we throttle at the MVHR unit end - not at the room terminals - which might well help) and whilst you can hear the air flow when boosting it's not offensive in any way and is not something that causes any issues even at night etc.
