I just had a couple of fire door linings replaced as they were not deep enough after I overboarded the stud wall they are set in. The original linings were made with 30mm thick timber, and I only realised this evening that the new linings are made of 20mm thick timber. One of the doors was also replaced with a heavier fire door , about 45kg. The frames seem sturdy and the doors close fine, but I’m concerned 20mm isn’t thick enough long term for such heavy doors. Also there is now a 4cm gap on one side of the doors filled with foam which doesn’t seem very fire safe…. What do you think?
Edited by 9namjam9
  • 2 months later...
