Mr Blobby Posted December 1, 2021 Posted December 1, 2021 (edited) Where should I site the panels on our new build? Options are... 14 panels on A + ( 14 panels at B facing north east or 8 panels at C facing South West ) Which is best, more panels on roof B facing North East or fewer panels on the smaller roof C facing South-West ? We have 3-phase supply into house so not limited to 4KW pv. Also, we are at home all day with EVs and a battery. I don't plan to ever get out of bed early to go to work again so early morning and evening generation is not a priority. My architect and M and E consultants say I should put the panels on the North-East roof. I'm not so convinced. Comments please. Edited December 1, 2021 by Mr Blobby
ProDave Posted December 1, 2021 Posted December 1, 2021 What are the ratings of the panels? For best self use the panels need to be on the phase you are using most. What is the reason for having 3 phase? My choice would be the 14 panels on A which is probably in the region of 4kWp, on a single phase dual MPPT inverter on your "main" phase that has most of the house loads and an EV charger. Then 8 panels on C which is likely to only be 2kWp on phase 2 with a second EV charger on that phase. Probably not a lot on phase 3.
Mr Blobby Posted December 1, 2021 Author Posted December 1, 2021 1 hour ago, ProDave said: What are the ratings of the panels? For best self use the panels need to be on the phase you are using most. What is the reason for having 3 phase? My choice would be the 14 panels on A which is probably in the region of 4kWp, on a single phase dual MPPT inverter on your "main" phase that has most of the house loads and an EV charger. Then 8 panels on C which is likely to only be 2kWp on phase 2 with a second EV charger on that phase. Probably not a lot on phase 3. Interesting what you say about the inverter configuraiton. Agreed, the 14 panels are to go on the front section. For the panels I was looking at the JA solar 370 panels to give 5.3kW. I guess the only way it works is for a 3 phase hybrid inverter, and dual MPPT for the other panels at B or C. That is what I was planning, something like the Solis 8 kW dual mppt hybrid 3-phase model. I'm assuming here that the inverter will balance the phases. Otherwise I need to split across single phase inverters with a max 4 kW on each phase?
