richo106 Posted November 26, 2021 Share Posted November 26, 2021 Hi We are renovating a bungalow and just starting to get down to some finer details regarding insulation. Obviously I would like to insulate the property as well as I can. Exterior insulation is not possible in our design, so we are planning to install 50mm PIR on the internal walls, however the cavity between the bricks is only 70-80mm and I'm almost certain there is some form of blown insulation in there (I could see some white fluffy insulation when I took a window board off) My question is how effective is this insulation? Is there a way of improving this insulation further during the build? Many Thanks Link to comment Share on other sites More sharing options...
A_L Posted November 26, 2021 Share Posted November 26, 2021 2 hours ago, richo106 said: My question is how effective is this insulation? Is there a way of improving this insulation further during the build? Looks like you have a blown mineral fibre, e.g. https://www.knaufinsulation.co.uk/products/supafil-40 With a thermal conductivity around 0.04W/m.K it is good enough that their is no cost effective replacement or anything you can do to improve it. Link to comment Share on other sites More sharing options...
richo106 Posted November 26, 2021 Author Share Posted November 26, 2021 1 hour ago, A_L said: Looks like you have a blown mineral fibre, e.g. https://www.knaufinsulation.co.uk/products/supafil-40 With a thermal conductivity around 0.04W/m.K it is good enough that their is no cost effective replacement or anything you can do to improve it. Thank you Link to comment Share on other sites More sharing options...
