gravelrash Posted November 15, 2021 Posted November 15, 2021 Just putting foundations EPS sheet down and the boards seem to have quite a large tolerance dimensionally, leaving gaps between boards up to 5/6mm. Is this normal for EPS? I have been gap filling but cant get into smaller gaps, but 3 layers going down with dpm between 2nd and third. Probably been covered before but cant find anything in the search.
SuperJohnG Posted November 15, 2021 Posted November 15, 2021 My insulated foundation from KORE had some variations between outer lengths and heights where they were cut but in building it I just filled with foam and cut the final block. The inner section which was all boards I staggered joins as I had three layers but those ones were pretty decent tolerances. As long as you stick to the overall dimensions you require it'll be fine.
gravelrash Posted November 16, 2021 Author Posted November 16, 2021 do you have to foam all the small gaps? ie 2-3mm
SuperJohnG Posted November 16, 2021 Posted November 16, 2021 2 hours ago, gravelrash said: do you have to foam all the small gaps? ie 2-3mm Is it an insulated foundation? If so I didnt. I filled large gaps, but small ones are fine.
