Local water main burst about an hour ago. Wife ran hot tap for some reason and drained the water so secondary loop pump was practically dry and making a noise. Currently all switched off hoping the pump isn't kna456d.
Is it worth installing a pressure sensor to turn off the loop pump if the pressure drops? Anyone done something like this?
You mean on the secondary loop?
Don't think we have. Are you thinking the loop pump might have sucked air in via the open tap?
This is what our instructions said that came with the pump
When using pump models with pump housing code 65B (item 9 in Figure 3), use the G1/2 check valve (item 14 in Figure 3) supplied in the packaging. This prevents water from flowing through the pump backwards when any faucet is opened, thus causing damage.
• When using a check valve other than the factory supplied one, pay attention to the
appropriate closing pressure.
• Install the check valve after the pump in the direction of flow, so that the arrows on the pump housing and on the check valve point in the same direction
