Adam2 Posted October 19, 2021 Posted October 19, 2021 Am I correct in thinking that this perimeter insulation strip used on the exterior of a floor screed is there for insulative benefits and not to do with expansion? If so, with all my external walls being EPS I can avoid having to install this? The floor build up if it matters: concrete slab, dpm layer, PIR, slip membrane, UFH pipes, 55mm screed
tonyshouse Posted October 19, 2021 Posted October 19, 2021 Yes, screed seems thin, needs pipe sleeves and movement joints in doorways
Adam2 Posted October 19, 2021 Author Posted October 19, 2021 5 minutes ago, tonyshouse said: Yes, screed seems thin, needs pipe sleeves and movement joints in doorways Was planning on Cemfloor which specifies min 25mm cover on pipes so assuming 16mm pipes I have 34mm cover but yes will be ensuring the contractor creates doorway joints. Though my question was really about the need for perimeter insulation given that the walls are EPS
tonyshouse Posted October 19, 2021 Posted October 19, 2021 No need, possibly on internal walls if masonry
