Digger1 Posted October 19, 2021 Posted October 19, 2021 The plan is to add a timber frame first floor to our bungalow which has painted bricks on the existing ground floor and then render. I assume the timber frame and existing brick has to be clad in some kind of board to limit movement between the timber and brick floors? Can anyone recommend the best option? (Was hoping to use a coloured render to avoid painting.) Thanks
nod Posted October 19, 2021 Posted October 19, 2021 You can use any of The through coloured renders Just grind the joints out of the brickwork prior to scratch coat
Digger1 Posted October 19, 2021 Author Posted October 19, 2021 What is the process where the timber frame meets the brickwork?
