nh26302 Posted October 13, 2021 Share Posted October 13, 2021 Hello, I am planning to have a SIP outbuilding built at the rear of my garden. It will come as a kit from the fabricators and will measure 6m x 4m. I will also having decking installed around the structure which will be 2m wide and will need to put a concrete slab down for it. I am thinking about the following 2 options for the foundations: Opt 1: dig a trench and fill with concrete and install sole plate (and sips) on 7N concrete block frame - as I am limited to a 2.5M height this will allow me to install 100mm insulation and screed. Opt 2: install a 200mm concrete slab (100mm hardcore + 100mm concrete) measuring 10m x 8m upon which I fix the SIP structure and will give me the necessary 2m around it for the decking and leave the insulation out, as height would be reduced Option 2 would be cheaper but am wondering how much impact not have insulation would be? Thoughts/advise would be greatly appreciated Thanks Nasim Link to comment Share on other sites More sharing options...
SuperJohnG Posted October 18, 2021 Share Posted October 18, 2021 This really depends on what the outbuilding is to be used for? I assume a nice living space given you want decking, hence insulation might be better. But again all relates to what you want to use the space for. Link to comment Share on other sites More sharing options...
