Triassic Posted April 4, 2017 Posted April 4, 2017 I've been offered a Baxi Air Source Heat Pump. It has the following model/serial number RO.9/1.MT. and C14MT0091. I've looked online and can't find much information, other than stuff in French. Can anyone identify what it is? I assume it's a rebadged model made by others. How much is it worth? Is it of any use?
Jeremy Harris Posted April 4, 2017 Posted April 4, 2017 (edited) I suspect that it may be a re-badged Carrier, and is probably quite old, as I think that Baxi only dipped their toes into the heat pump market for a couple of years or so, around 2009/10. If it is really a Carrier, then it's likely that parts and manuals are available, the trick will be trying to find the exact model, and I suspect the only way to do that would be to compare photos. Edited to add: I found this very basic manual: https://www.mytub.co.uk/product_images/baxAmbiflo_brochure_Oct_10_comp.pdf and this list of prices: https://www.mytub.co.uk/baxi-air-source-heat-pumps-products-1 Edited April 4, 2017 by JSHarris
Triassic Posted April 4, 2017 Author Posted April 4, 2017 This what it looks like and the second photo shows the data label.
PeterW Posted April 4, 2017 Posted April 4, 2017 Looks like a college / installer demo unit. Has it ever been powered up..? R410a has a POE oil in it as a lubricant that can settle if the unit is not used - you may also have low gas pressure if its never been run so I would get a refrigeration engineer to give it a once over and check the pressure. Flight case on its own is worth £100, unit is not worth much more than that as its 10 years old so anything more than £150 I would walk away.
Jeremy Harris Posted April 4, 2017 Posted April 4, 2017 (edited) It's not a Carrier, as far as I can tell. It's not made by Baxi, either, I'm pretty sure. As Peter says, it's 10 years old and so isn't worth much, but as it's been stored well there's no real reason why it shouldn't be able to be put into service, after a few checks. The problem seems to be finding an installation and user manual. I've managed to find a parts list, but it's not a lot of help: http://www.ricambiclima.it/public/media/20121161722200.AMBIFLO-90.pdf Edited April 4, 2017 by JSHarris
