connick159 Posted October 8, 2021 Posted October 8, 2021 (edited) Hi all, I'm working on the ensuite now and have seen this Marmox Plinth as a good option to build a shower tray up on top of the slab so I can get drainage underneath. (cant dig into the slab so have to go above it and out the wall for the drain.) The plinth is fixed to the slab with a flexible, cement based tile adhesive. On top of that plinth I would then install a showerlay such as this... Marmox showerlay. My question is: Could I substitute the plinth with some leftover 100mm Celotox PIR insulation? It seems like essentially the same thing. Is there any reason why this is a bad idea? Thnks in advance. Edited October 8, 2021 by connick159
connick159 Posted October 11, 2021 Author Posted October 11, 2021 For reference - decided to order the plinth and shower lay as above.
Olf Posted October 11, 2021 Posted October 11, 2021 You did the right choice: XPS have twice the compressive compressive strength of PIR and does not degrade in contact with water 1
