Dan F Posted October 5, 2021 Posted October 5, 2021 (edited) Has anyone done modelling of any kind using past rainfall and evapotranspiration data to determine the ROI for differing sizes of rainwater havesting tank vs. a small mains accumulator. I've found some fairly local past data for 2020 [1] and some interesting theory [2] that details a method that can be applied to model this. For now I'm using a basic approach with a fixed number of mm irrigation per day, depending on the month (rather than simulating a control system that irrigates based on soil moisture/rain) but initial results show water usage of 360m3/yr with a small mains accumulator and 330m3/yr with a large 6800l tank. If this is correct, the ROI is something like a couple of hundred years and that's ignoring additional maintaince to cleare/replace filters. [1] https://crondallweather.co.uk/daily-monthly-and-seasonal-evapotranspiration-statistics-for-crondall/ [2] https://agriculture.vic.gov.au/__data/assets/pdf_file/0008/577025/What-is-evapotranspiration-and-how-do-I-use-it-to-schedule-irrigations-Tech-Note.pdf Edited October 5, 2021 by Dan F
PeterW Posted October 5, 2021 Posted October 5, 2021 Yep the cost of the tank and controls will far outweigh any ROI that isn’t measured in decades. Worth seeing if you have anywhere to “hide” IBCs as they are a cheap option - I’ve buried them before in steel cages and concrete capped them but you need to be sure they will work for you like that.
Dan F Posted October 5, 2021 Author Posted October 5, 2021 52 minutes ago, PeterW said: Yep the cost of the tank and controls will far outweigh any ROI that isn’t measured in decades. Well, I think we'll put a tank and controls in anyway, the idea being garden looks after itself a bit more. So I was only looking at the additional cost of larger tank (7,000l) and additonal associated excavation/muck-away vs. 3000l accumulator + additional filters etc. But the large tank, if I've modelled it correctly, would only save £50/yr mains water as when you need to irrigate it typically hasn't rained, and a 7000l tank only lasts a few days in the middle of summer. 52 minutes ago, PeterW said: Worth seeing if you have anywhere to “hide” IBCs as they are a cheap option - I’ve buried them before in steel cages and concrete capped them but you need to be sur Will look into this, thanks!
