MikeSharp01 Posted April 1, 2017 Posted April 1, 2017 (edited) Been trying to download CAD drawings from Marley. Got this message: URL: http://www.marleyplumbinganddrainage.com/support-and-advice/cad/ Microsoft OLE DB Provider for ODBC Drivers error '80040e0c' Command text was not set for the command object. /CAD.ASP, line 367 Thought must be a Marley issue as this is an SQL error, so off I went to flowplast and got this message: URL: https://www.fastrackcad.com/CADFrame.ASP Microsoft OLE DB Provider for ODBC Drivers error '80040e0c' Command text was not set for the command object. /CADFrame.ASP, line 369 Looks like it might be me, but cannot see how? Have those damned hackers cut off our supply of CAD blocks? Edited April 1, 2017 by MikeSharp01 Added URLs
Jeremy Harris Posted April 1, 2017 Posted April 1, 2017 (edited) I've just tried it from a Windows machine and get the same error on both links. Not sure what it means, but there are a few here that can probably make sense of it. I'll try it from a Linux machine in a minute, to see if there's a difference. Edited to add: It's just the same on this laptop that's running Linux Mint 18.1, so it looks like it may be a server-related problem. Edited April 1, 2017 by JSHarris
MikeSharp01 Posted April 1, 2017 Author Posted April 1, 2017 Thanks Jeremy, I thought it very odd that two CAD platforms have the same error, two lines apart. Maybe its actually one cad platform serving both masters. I am sure I got this error somewhere else yesterday - will drill back on my laptop and see what it was about.
PeterW Posted April 1, 2017 Posted April 1, 2017 @MikeSharp01 Its the same link... Looks like both use a service called FastTrackCAD the links are identical - I wonder if they have embedded an old service and its been recently updated http://www.fastrackcad.co.uk/CAD.ASP?Company_id=108 You can register directly with them to get access - no idea if this works as I'm not registering to find out !! https://www.fastrackcad.com/Portfolio.asp
