We had a LG Therma V installed last year, just before lockdown. I'm still not convinced that the thing is setup correctly - water temp, flow temp, house temp etc, also if we should be using with an external thermostat (NEST), or just leaving to run?
Can anyone give any advice on where to start - I'd like to be able to work through from start to finish to make sure that everything is correct and that we are not running a system that is not as efficient as it should be.
Thanks in advance,
Andrew
I have the monoblock Terma V, while not the same animal the principles are the same.
Lets start with what your DHW and heating flow temperatures are set to?
@ProDave - thanks for the fast response.
DHW - 50 degrees C
Heating Setpoint - 38 degrees C
House Thermostat - Nest, Located in Hallway, set to 20-21 degrees C
I've got a LG ThinQ unit connected which allows view of a number of the stats remotely - In my case I am using HomeSeer to grab the data.
Andrew
  • 2 weeks later...
