CotswoldDoItUpper Posted September 27, 2021 Posted September 27, 2021 As it says on the tin really. What is the maximum difference in height between two loops of UFH the same zone? We have a couple of steps in the hallway and would like to run it off the same manifold located in the higher area. Ta!
PeterW Posted September 27, 2021 Posted September 27, 2021 It’s fine - as long as the manifold is above the loops the AAV works to remove the air 1
CotswoldDoItUpper Posted September 27, 2021 Author Posted September 27, 2021 4 hours ago, PeterW said: It’s fine - as long as the manifold is above the loops the AAV works to remove the air Thanks!
