Hi all.
Not far off starting a conversion on our garage. Was built approx 18months ago.
Single block skin with render finish. The plan is to stud out inside, rigid insulation board between studs then a sheet of rigid over the face, then batten (service void) then plasterboard. Obviously taping and sealing for vcl etc.
What I'd like to know is what's the best idea for ventilation within the cavity? We have vents ontop of the fascia, underneath the first corse of slates but that's it. Would this suffice? Or is there any ideas? Or do I leave as it it...
As you can see the rear wall is retaining some of the garden at the moment but will be tanked etc once the new drainage line etc is put it. There is no signs of damp inside etc either.
Much appreciated
Okay.
Don't these need fitting towards the bottom of the "cavity"?  As the photos show the wall is block plus two corse wide in the bottom?.
Thanks for suggestion @TonyT much appreciated
