ianR1 Posted September 14, 2021 Share Posted September 14, 2021 The screed is going to be done on Friday and I have the pressure test on the finally finished system planned for tonight. I understand its 5 - 6 Bar for an hour and I should be good but what pressure do you recommend leaving in the system whilst they screed ? I'm going for a sand/cement screed. Link to comment Share on other sites More sharing options...
RHayes Posted September 14, 2021 Share Posted September 14, 2021 Leave the pressure in it. If you do feel the need to take some out then drop it to 3bar but I would definitely not go less. The screed shouldn't make any difference but you want to be able to see or notice straight away if a pipe is damaged whilst screening, with a trowel for example. Link to comment Share on other sites More sharing options...
Fly100 Posted September 14, 2021 Share Posted September 14, 2021 Pressure will rise slightly as the floor cures due to heat produced from curing process. Link to comment Share on other sites More sharing options...
ianR1 Posted September 14, 2021 Author Share Posted September 14, 2021 Super - Thanks for the replies Fingers crossed ! Link to comment Share on other sites More sharing options...
