WWilts Posted September 13, 2021 Posted September 13, 2021 Builder inclined to make do with 90-ish degree bend at bottom of soil stack from first floor WC/shower. Supported / encased in concrete (lean mix I think). Is a proper rest bend with foot absolutely necessary in this case?
markc Posted September 13, 2021 Posted September 13, 2021 4 minutes ago, WWilts said: Builder inclined to make do with 90-ish degree bend at bottom of soil stack from first floor WC/shower. Supported / encased in concrete (lean mix I think). Is a proper rest bend with foot absolutely necessary in this case? The foot stops the bend from rolling/sliding downwards. If properly supported and prevented from moving with concrete then no problem 1
WWilts Posted September 13, 2021 Author Posted September 13, 2021 Does the radius of the bend make a difference? Currently fairly short radius bend put in at what will be the bottom of a stack.
markc Posted September 13, 2021 Posted September 13, 2021 Small radius is ok, I wouldn’t use an elbow at the bottom of the stack to reduce hammer. As long as it’s a bend it will stay clear 1
