Ferdinand Posted September 6, 2021 Posted September 6, 2021 I've been working though a Land Registry deed for a property I own today. And I came across this on the deeds, in the "Property Register" section. "(day.month.2017) An agreement dated dd.mm.2017 between (1) abc and (2) xyz Ltd relates to the south western boundary of the land in this title. Note: copy filed". How do I get hold of a copy of the "copy filed" agreement? Can I do it or does it need my solicitor? Ideally I need it within the next 48 hours. Thanks Ferdinand
Temp Posted September 6, 2021 Posted September 6, 2021 I might be wrong but I think there is another database called the "charges register" so if its not at the Land Registry perhaps try there? I think these records are/used to be maintained by local councils but the government is trying to provide central access. Not every area has joined the central scheme which is here.. https://search-local-land-charges.service.gov.uk https://search-local-land-charges.service.gov.uk/check-if-an-authority-is-migrated
Ferdinand Posted September 6, 2021 Author Posted September 6, 2021 4 minutes ago, Temp said: I might be wrong but I think there is another database called the "charges register" so if its not at the Land Registry perhaps try there? I think these records are/used to be maintained by local councils but the government is trying to provide central access. Not every area has joined the central scheme which is here.. https://search-local-land-charges.service.gov.uk https://search-local-land-charges.service.gov.uk/check-if-an-authority-is-migrated On the deeds it is listed under "Property Register", not "Charges Register" - so I don't think it will be on there. But thanks.
Temp Posted September 6, 2021 Posted September 6, 2021 (edited) Google found.. How to request/purchase 'Copy Filed' documents? https://help.landregistry.gov.uk/app/social/questions/detail/qid/109/~/how-to-request%2Fpurchase-copy-filed-documents%3F See follow up questions and replies at the bottom. Suggests your solicitor could get it online. Edited September 6, 2021 by Temp
Ferdinand Posted September 6, 2021 Author Posted September 6, 2021 16 minutes ago, Temp said: Google found.. How to request/purchase 'Copy Filed' documents? https://help.landregistry.gov.uk/app/social/questions/detail/qid/109/~/how-to-request%2Fpurchase-copy-filed-documents%3F See follow up questions and replies at the bottom. Suggests your solicitor could get it online. Thanks.
