Recently I had a Nibe F2040 & SMO20 installed. Whilst the recent weather definitely doesn't require cooling I would like to know if the system I've got can be used for cooling in the future.
After quite a lot of research I believe it can, however some parts of the manual talk about an accessory being required, however it doesn't state what that is??
If I were to enable cooling to be permitted in the Service menu, would I damage anything? Are all the pumps and valves etc. designed to run for cooling as well as heating?
I am aware that I would need to be careful about the relative humidity / dew point to prevent condensation etc,
Has anyone else enabled it on their Nibe units?
I have the same unit, although with the SMO40. I have cooling enabled on mine and when I purchased in 2017 it required an additional cooling module to be able to cool. I was also told I needed the SMO40 controller.
  • 3 years later...
No extra accessories were required.
I had to access the service menu by holding the back arrow for 7 seconds, and then selected permit cooling.
  • 1 month later...
