ChrisM85 Posted August 18, 2021 Author Posted August 18, 2021 2 hours ago, markc said: UFH generally runs around 25 degrees and gives a fairly even floor temperature. electric heating mats can result in much higher hot spots if a towel or something is left on the floor The minimum setting on my TMV for the manifold is 25° with max being 55° I believe. Assuming the FFL surface temp would be between 10-15° lower then the water in the UFH pipe I guess at a final set point of 40° but that's a guess.
ChrisM85 Posted August 23, 2021 Author Posted August 23, 2021 Apologies been held up will be next weekend
ChrisM85 Posted September 6, 2021 Author Posted September 6, 2021 Hi all, sorry for the delayed response its been a busy few weeks. It worked anyway. I scraped the excess hardwood back with a fresh Stanley blade until the delamination would push down without resistance. Then I got a pic under the delamination to lift it just high enough to fit a 14 gauge blunt needle under and filled the cavity with cascamite. I then pushed it down wiped off the excess with a damp ragand weighed it down with a piece of damp first layer, then a 2"x2" tile with four 7n blocks on top for 24 hours. To finish it I'll rub a small amount of adheasive (same colour as the floor) into the slight gap but it's hardly noticeable then rub it down with a damp cloth. Worked a dream. Thanks all for your input. 4
