joe90 Posted July 16, 2021 Posted July 16, 2021 I have a leaky tap (swivel head) and found the “o” ring split so replaced it with one from the garage. However, the “O” rings grabs making the tap stiff. Tried Vaseline to no effect. Are these “O” rings different (white) to the black ones used on mechanics?
markc Posted July 16, 2021 Posted July 16, 2021 The white seals are usually PTFE, Nitrile should be ok but rubber will grab when dry or with water. 1
