I'm measuring up to fit the first of my P5 flooring. The room length is 4250mm, so 50mm larger than 7 boards. 25mm gap at either end and no slicing boards in half.
What is the maximum expansion gap you would accept before you decide to start slicing boards?
25 be ok but might have acoustic implications. Probably find it's a bit less than 25 with the tolerance on boards and joints not being 100% tight
