TryC Posted June 6, 2021 Posted June 6, 2021 Hi All, I recently painted my doors (which had been previously stripped) with alkali resisting primer (per the instructions of using the type of paint removing paste). I have one coat on the wood work so far and will go for another coat, but I have noticed some cracks in the wood work. Can I use easifill to fill the cracks or would it be best to get a wood filler? I'm guessing painting/filling the crack with paint is not ideal! Any advice would be appreciated.
PeterW Posted June 6, 2021 Posted June 6, 2021 Nope ... go to Toolstation and get their wood filler in the small tubs. Great stuff, easy to sand and doesn’t show through paint.
TryC Posted June 6, 2021 Author Posted June 6, 2021 2 minutes ago, PeterW said: Nope ... go to Toolstation and get their wood filler in the small tubs. Great stuff, easy to sand and doesn’t show through paint. thank u! I had a look at toolstation, there are so many, can you please recommend one please?
PeterW Posted June 6, 2021 Posted June 6, 2021 Yes the one I linked .. https://www.toolstation.com/everbuild-multi-purpose-wood-filler-250ml/p15238 1
TryC Posted June 6, 2021 Author Posted June 6, 2021 11 minutes ago, PeterW said: Yes the one I linked .. https://www.toolstation.com/everbuild-multi-purpose-wood-filler-250ml/p15238 oh sorry! I didn't see the link. thank u! Another question, I live in an old house, and the skirting board has come away from the wall, can I use easifill to fill this gap? or is easifill only meant for filling smaller gaps?
PeterW Posted June 6, 2021 Posted June 6, 2021 1 hour ago, TryC said: the skirting board has come away from the wall Countsink some holes then plug and screw it back. Then fill the holes. Decorators caulk along what should be a smaller gap.
TryC Posted June 6, 2021 Author Posted June 6, 2021 2 minutes ago, PeterW said: Countsink some holes then plug and screw it back. Then fill the holes. Decorators caulk along what should be a smaller gap. i'M GOINg to have to google these words as I do not know what they mean
